Question about Electronics - Others
What is the format for microSD card for iPhone 6 7
6ya staff
SOURCE:
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: when i try to format my microSD 4gb card my pc freezes
sorry that occurs when th internal memoy is corrupted.
Posted on Jun 22, 2009
Anonymous
SOURCE: cannot format PNY 4gb microsd card
I WAS TOLD BY MOTOROLA THAT THE V3M WOULD ONLY TAKE A 1 GB TRANSFLASH MEMORY CARD. I TO HAD A 4 GB MEMORY CARD AND IT WOULD ALWAYS SAY , CAN NOT FORMAT, TRY AGAIN? I BOUGHT THE 4GB AT THE STORE WHERE I GOT MY PHONE. I BOUGHT A 1 GB MEMORY CARD AND IT WORKS FINE NOW. I HAVE NO IDEA WHY THEY SOLD ME A 4 GB IF IT WOULDN'T WORK WITH MY PHONE . HOPE THIS SOLVES YOUR PROBLEM IF YOU HAVEN'T ALREADY .....
Posted on Jun 25, 2009
Anonymous
  • 208 Answers
SOURCE: microsd card will not format
Cards > 2GB are MicroSDHC cards. Your player and reader will have to be compatible with HC cards to use it.
Posted on Sep 02, 2009
  • 102366 Answers
SOURCE: microsd card won't read
You need to use a microSD card, not a microSDHC card. microSD cards max out at 2GB, anything larger is a microSDHC.
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
Posted on Feb 09, 2012
  • 102366 Answers
SOURCE: MP66 can't read microSD kingston
The MP66 can read microSD cards. Your 8GB card is actually a microSDHC card and will not work with the MP66. You need to use SD and microSD cards, 2GB and smaller.
Posted on Sep 04, 2012
How to remove write-protection on a micro sd card
  1. Connect the microSD card to a computer
    Use a memory card reader to connect the microSD card to a computer for formatting. In case you're using an SD card adapter, ensure that the write protection key is in the unlock position.
  2. Locate the card Right-click My Computer, and click Manage. Go to the Disk Management tab on the left pane, and locate your microSD card from the list of available disks.
  3. Format the microSD card Right-click on the microSD card's drive, and click Format. This eliminates all data, including corrupted files that cause write protection in storage devices
Nov 09, 2016 | Electronics - Others
Not formatted ,copy from my microsd 4gb claas 2 memory card,also after some tym of insertion the memory card is not showing
It would be helpful to know what device you're talking about, what operating system and what your problem is. All I can say at this point, is to remove the memory card and reinsert it and see if it shows up them.
Nov 28, 2013 | Transcend 4GB microSDHC Memory Card Class...
My micro sd card is not working on my phone and in computer? what should i do?
usually memory cards have to be formatted for use on the phone,do this by inserting in phone and use the phone settings to format it,also use the phones additional software to connect to computer.
you need to give more details but for iphones its itunes nokia its nokia pc suite etc
hope this helps
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
What is the most capacity of Micro SD that suport of that cellphone!
The SDA announced the microSD format at CTIA Wireless 2005 on March 14, 2005, and approval of the final microSD specification was announced on July 13, 2005. At launch, the microSD format was available in capacities of 32, 64, and 128 MB. SanDisk introduced a 2 GB microSD card in July of 2006, initially priced at 99 USD. Since then, prices for flash memory devices have fallen dramatically. The same 2 GB card as of April 2009 can be found for as little as 12 USD at department stores, and as of May 2009 for as little as 6 USD at online electronics stores. At present date Jan 2010 a 16 GB micro SD card class 2 comes for about $40 and a 4 GB class 2 micro SD card comes for about $8.
please rate my answer as helpful. thanks. Joe
Feb 23, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Sandisk 16gb microsd formatting incorrectly
Hi unfortuanley you have been sold a fake card
http://memory-cards-blog.blogspot.com/2009/12/dane-elec-8-gb-compactflash-memory-card.html
Please can i ask that you leave ffedback and vote if this has been useful
Feb 09, 2010 | SanDisk 4GB microSD High Capacity Memory...
MicroSD card problems
Try letting the phone format the card. 1) Backup the music files you already have on the card. 2) From your computer, right click on the drive representing the card and re-format the card. 3) With the phone turned off, insert the card into your phone. Power on the phone and follow the steps to have your phone format the card. 4) Now copy the files back to the card using your computer.
See if that does the trick. If not, try performing the same steps as above, but instead of re-formatting the card in your computer, go into disk manager and delete the MicroSD card's partition (be careful that you select the correct drive representing your MicroSD card). When you re-partition the card, uncheck the "format" option, which will leave the card unformatted. Then let your phone format the card.
Good Luck!
Aug 13, 2009 | Samsung SGH-P850 Cellular Phone
1GB MicroSD card detecetd by computer as 0 memory device
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
Electronics - Others Logo
59 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
