SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
SOURCE: could someone please tell me where can i buy
OfficeMax and Office Depot may have them.
Storemont (online) has the Royal Alpha 601 ($6.49): http://www.stormont.basics.com/product.asp?dp=2098041&f=
SOURCE: ROYAL ALPHA 587 CASH REGISTER
set to program... press the number 1 then press tax one enter in 4 digit tax then press amount total tend
SOURCE: The paper doesn't advance when I hit the return
Hi!
I'm going out on a limb here.
I assume the carriage returns but the line does not advance. Close?
- There is a setting for the linespacing which is either 0 (zero), or 1, or 1 1/2 or 2
Likely, this has been inadvertently moved.
- Also, there is a way of disengaging the linespace mechanism to allow typing to be made on unevenly space forms. This might have been moved.
Please feel free to contact me anytime.
SOURCE: My Royal Alpha 2001 typewriter has been unused for
Hi!
