SOURCE: Oki c5800 laser printer
http://www.c5800.co.uk/index.asp?printername=C5800&menumode=0&content=C5800downloads
At the bottom you will see the file C58uEN1.pdf
Go to page 89
SOURCE: OKI C5800 ERROR MESSAGE- DRUM
hi!!!
try to check the drum first!!!
clean it with the dry tissue?
there a lifespan of the drum
i have the same problem with that.
my drum capacity is only 30,000 copies
so then i replaced it! and works fine now
so try to replaced the drum it might on it capacity
or clean it
try to email me [email protected]
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
SOURCE: have a oki c9800 ...gives error 923
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
SOURCE: My Oki C5800 is not printing any black- toner is
First of all try cleaning the black LED head with an alcohol wipe, next check the connection to the black LED head and make sure there is nothing blocking the light between this head and the top of the image drum. It may also be worth swapping the LED head between colours to see if the problem moves colour or stays with black. If after moving the head the problem still happens with black then it may indicate a problem with the image drum or an electrical problem. If you have another unit you could try swapping the drum and toner between units.
