Check the connection to the torch from the drive box ,could be shorting out ,jiggle the connection ,if that doesn't work it could be a bad connection in the trigger itself ,check the connection with a jumper wire from the trigger to the connector ,by passing the trigger , and hooking wire up to the pos.on the connector ,does it have a fuse reset on the panel ,check the fuse
SOURCE: MIG wire is always hot without pulling trigger
Check your manual, there are a lot of mig units on the market that are alway "Live" alternatively, the relay has either shorted or you have wirering problem on the switch.
SOURCE: mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
SOURCE: I have a Campbell Hausfeld MIG Welder 80, The wire will not feed,
Here's a link to the Campbell Hausfeld web page. Look under "Service Center" for "Find a Part." I hope this has what you need.
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
SOURCE: northern tool mig welder,120 volt with gas.The
This welder is made in China. I have one and it works fine. Parts and service are available from northern tool. 1-800 # is on the book. FYI this 135 gas no gas looks exactly like the Lincoln SP135 and Lincoln workmate 135. GOTO the lincoln site and bring up the manual. It is a free download and is a much better manual than the one it came with. I agree with the previous post. Put a continuity test on the 2 wires that come from the trigger. there is a wire diagram in the book that came with it. Hope this helps.
Paul
SOURCE: I have a Lincoln pro core 100 when I pull the
content.lincolnelectric.com/pdfs/products/navigator/im/IM781.pdf
manual above.
Often this is caused by the Motor Driver, Electronics failing, you need to troubleshoot the PCB, Motor Drive circuit.
This is generally where you find the problem. Of course check ALL connections etc First too. Also Check out your switch too, sometimes they fail.
Wire feed stoppages and wire feed system malfunctions can adversely affect the welding arc and create irregularities that may weaken the weld bead. Birdnesting, a tangle of wire that halts the wire from being fed, is a common problem. You can resolve birdnesting by flipping up the drive roll and pulling the wire back out of the gun. Next, trim the affected wire and re-thread it through the feeder and back to the gun. If the welding specifications allow, decrease the drive roll tension, use a larger diameter wire and/or reduce the distance the wire feeds (use shorter cables) to minimize the chance of birdnesting.
Burnback is also very common. It results when a weld forms in the contact tip, and usually occurs because of too slow of wire feed speeds and/or from holding the MIG gun too close to the base metal during welding. To correct burnback, increase the wire feed speed and lengthen the distance of the MIG gun from the workpiece (the nozzle should be no further than one-half inch from the metal). Replace burnback-damaged contact tips by removing the nozzle and the contact tip (which may be melted to the wire), snipping the wire, installing the new contact tip and replacing the nozzle with one that has the appropriate tip recess for the application.
Other causes of wire feeding problems include liner blockages, improperly trimmed liners (too short/burred/pinched) or the wrong size liner. To remedy these problems, replace any liner if you find a blockage, always trim the liner according to the manufacturer’s direction and be certain you are using the correct size liner for the welding wire diameter.
troubleshooting how to, fix the PCB if you need to.
http://weldingweb.com/showthread.php?s=a8f5deacd13615dae178740c72f32f93&t=4385
Lincoln Support website below, please go here and obtain your Service and repair manual, one simply cannot troubleshoot without one, it just makes it a lot easier with one too.
http://www.lincolnelectric.com/
Online help below.
http://www.lincolnelectric.com/knowledge/askus/default.asp
