Maytag Bravos HE Top Load Washer. Purchased from Home Depot 2/2011, model # MVWB300WQ.
Hi Andrea, your machine has a bad tub bearing. Considering the age of your machine, you may want to consider replacing the unit. I would call your local repair company and get a quote for the repair. Hope that helps.
Call a repairman you have a broke seal
Jimmy is correct your bearings are bad and the machine is going to need to be removed before it can be repair. It will need to be turned over and will make a mess. The bottom may be to costly to have some one repair it. And may be more economical to just replace the whole thing. If its a great machine you can rebuild it and first you need to do is inspect for damage to parts before deciding. If the gears and clutches are damaged you will be paying more and more then just a seized bearing.
SOURCE: Maytag Bravos top load washer
Did you try readjusting the load, or maybe removing heavier items?
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and
removal:
Also check on the SEAL on the door and drum, it can also be worn out and reposition the drum to move out which can result in the noise when the spin is activated.
