Question about Welding Tools
How to change a power cord on a clarke 215 upright
After removing six screws, how do I get case apart to repair electric cord
How do i replace the power cord on electrolux nimble - Fixya
www.fixya.com/.../t25091002-replace_power_cord_electrolux_nimble
Sep 11, 2014 - Power cord is frayed next to body, need to replace it. how do i get ....See all Electrolux EL8602A Nimble Upright Bagless Vacuum Questions.
Amazon.com: Customer Reviews: Electrolux Nimble Upright ...
www.amazon.com/...EL8602A/.../B004GUFWBM
Amazon.com, Inc.Electrolux Nimble Upright Bagless Vacuum, EL8602A ... The rotating brush on/off buttons are located right under the soft-touch power button high up at .... Cord is a $30replacement part, which I'm regretting not doing from the get-go, due to ...
Apr 13, 2015 | Electrolux EL8602A Nimble Upright Bagless...
No power to switch. ts there a reset button?
Check the power plug cord, might be bent so often that the internal wire)s) are broken. You can cutoff old plug and replace with new one.
Jun 08, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Floor brush won't turn.
if yours is a dual motor unit a microswitch in the base of the vac powers the brush roller, additionally the carbon brushes may need replacement..far cheeper than a motor.
or your belt may be stripped or streched due to string or hair binding the bearing
Aug 03, 2013 | Clarke CombiVac 12 Bagged Upright Vacuum
Need a new torch assy for my clarke 130.
Go to your nearest Praxair store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at all welding stores.
Dec 02, 2010 | Clarke Power Products Clarke 130EN...
My clarke compressor keeps blowing the fuse in the plug on start up. any ideas!!!! i`ve changed the lead and plug
if the compresor is tight it would blow fuses, or the starter capasitor is leaking,,, (below power)
but its more likley you are using the compresor on a long extension lead and the power drop in that lead is causing the problem,,,if this is so,, use a much thicker extension lead...2hp motor = 2600 wats? at start up,
Oct 28, 2009 | Clarke Power Products AC2002A 2 Hp Air...
I have a clarke 130en mig with gas and it will not weld
The most common problem is that people still try and run the welder with extension cords. 10 ft,25ft,50ft,100ft, these cords all drain and can't supply the energy needed as if you were to plug it straight into a wall outlet. well I don't have a plug outlet where my work is, I need a extention cord. The only solution for not having a handy outlet is a Generator. that will supply the necessary voltage needed to do the job. EXTENSION CORDS ARE A NO NO. also, always double check your ground.
Hope this was helpful, please post a rating good or bad, thank you.
May 02, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Convinience Question
cordless is easier to use, but if you use the sander for a big job the cord models are better for due to continues power supply.
Aug 27, 2008 | Clarke Power Products CT4012 3"X18" Belt...
Need new mic for Raymarine #1VHF Radio 215 DSC
Hello rikirsch,
For replacement microphones for the Ray 215 DSC you can contact the manufacturer via their website http://www.raymarine.com. It appears there are two different versions available, a traditional style handheld microphone and a multi-function handset style mic.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 03, 2008 | Radio Communications
Welding Tools Logo
73 people viewed this question
Top Welding Tools Experts
David Soto
David Soto
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
