Gail Twyman Posted on Jul 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mp3 doesn’t charge or hook up to my computer how can i get it to charge and hook up to my computer without buying a new sandisk?
Steve Pack
Level 3:
  • Audio Player... Master 7,125 Answers
  • Posted on Jul 25, 2019
Steve Pack
Level 3:
Answers
7125
Questions
Helped
2273401
Points
27938
You don't. The battery is dead, so replace the player, I have replaced 3 of mine, replacements are not expensive. If you did not keep a backup of music that is on player it will be expensive lesson. Buy 2 and have the same music on each and put one aside as a backup.
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Jun 11, 2008
SOURCE: SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
i tell you connect to the computer your device
and right click on your device and format it
Anonymous
  • Posted on Dec 19, 2008
SOURCE: my computer wont reconize my mp3 player
Down load the firmware on Sansa's website. I have a Sansa 250R and it wouldn't work with the new replacement usb (Griffin) cord I bought at Best Buy. So I bought a Sansa Fuze and the cord that came with it worked on the E250R. Huh? Yeah, go figure...and oh, that replacement Griffin usb cord I bought worked fine with the new Fuze. I came real close to buying a new battery for the E250R but instead invested that money in the Fuze.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 01, 2009
SOURCE: THE CLIP WON'T CHARGE
The hold switch might be engaged - unlock it.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Anonymous
  • 17 Answers
  • Posted on Mar 08, 2009
SOURCE: My sanDisk Sansa Clip MP3 Player will not charge
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Anonymous
  • 54 Answers
  • Posted on Apr 06, 2009
SOURCE: Lost software CD for SanDisk 8.0GB MP3 player. Where can I get an
You can get the software and user manual from this site. It says you have a Sansa View, so this is the page for that model (you will see it on the right side of the page).
http://www.sansa.com/support/sansa_view/faqs
Computer doesn't notice MP3 player
the requirments are not made. i had the dame problem, just download sansa updater installed, can you help my problem
2answers
Connecting mp3 player to old computer without recharging outlet
To my knowledge, the only way to charge an mp3 on a computer is with a USB drive, so if the computer is so old it doesn't have USB ports, then you may want to look into buying a new computer or asking a friend to borrow theirs.
13helpful
3answers
SanDisk, 2 GB Sansa mp3 player won't charge
You MAY have a power glich. In which case, hold the power/menu botton down for 20 seconds or more, then connect it to the computer.It's best if you use a USB input that's NOT part of a Multi-USB base, as those DO cause power gliches.
Wont turn on.
http://www.sandisk.com/sansa/#/support-0/
Lost my software
Sandisk website has the software for free
Will not connect
but a new usb cable for like $4 - $7
Cannot charge my sandisk on computer
Sounds like the battery may have come loose in the inside.
You can unscrew the back and remove and re-seat the battery, then try charging it again.
Best of Luck.
My computer doesnt recognize my sansa
their are over 11000 problems with this sansa 4GB player. IT is strongly recommended not to buy this ...My screen frozen, computer undection USB, songs deleted by itself, something error.and ETCCCCCCCC>.. latino, ur right, try reseetinn it , then unistall drive..might fix the problem..good luk ..
 Grubhead
Grubhead
SmartAviator
SmartAviator
