Question about Kenmore Refrigerators
My bottom freezer defrosted overnight. What number should it be set at for optimum performance. I have a kenmore 67942 about 10years old.
6ya staff
SOURCE:
Anonymous
  • 623 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
While the freezer is cold, cut out defrost thermostat and measure resistance, if open, replace, if it's ok check defrost heater.
Temporarily short the wires that went to the defrost thermostat and now force defrost.
If no defrost, you have a bad adaptive defrost board.
Posted on Aug 29, 2008
Anonymous
  • 750 Answers
SOURCE: Freezer not defrosting
Hello pumpguy2
Welcome
You said, you have a Kenmore bottom Freezer Model 596.73503201. It works fine but the freezer has stopped defrosting. Any suggestions?
It is supposed to be auto or self defrosting.
What do you mean you are getting ice forming in the freezer?
Waiting for your response and more detailed explanation.
Huuum
Posted on Oct 12, 2008
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Posted on Nov 06, 2008
douglas smith
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
Bruce Hathcock
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
I have a kenmore frost free freezer. the model number is 253.26432100. please tell me how to initiate a defrost check on this type of freezer. it has a digital thermostat and no manual timer that you can...
Hi.
You cannot manually initiate a defrost check on this unit because this is an automatic self defrost cycling fridge/freezer.
There is no way to start a manual defrost check. Manual defrost can be done disconnecting the power plug from main overnight. In that case check the drain pan located at the bottom of the unit before defrost is done.
If there is ice buildup on condenser coil, then defrost system is malfunctioning.
In that case the parts in the defrost system must be tested.
Here temporary link to user manual.
If that does not work, use this link.
Here link to part list and diagram.
Regards.
Mar 10, 2010 | Kitchen Ranges
My kenmore 106.5706 has good freezer operation but warm refrig side. Fridge bottom vent had ice buildup and there was also no air from the top vent. I unplugged overnight to let ice melt then reconnected....
Most times that is the first sign of a defrost problem. Yours has a electronic defrost control part number 4388932 inside the fresh food section that may be bad. Look in back of freezer is frost building up on rear wall. If yes we need to check the defrost heater, defrost thermostat and the defrost control board. Thanks, Sea Breeze
Dec 17, 2009 | Kenmore Refrigerators
Kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Sep 10, 2009 | Kenmore Refrigerators
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 19 frezer on bottom
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
