Question about Amana Refrigerators
How do you remove the front grille from an Amana refrigerator (2004 - bottom pull out freezer, model # ARB2217CSR?
6ya staff
SOURCE:
catriver
Ron Marek
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Anonymous
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
Anonymous
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Anonymous
    SOURCE: Amana bottom freezer not working on model abb2524deq
    I replaced the solenoid and my ice machine starting working again.
    Posted on May 16, 2009
    Lite bulb in freezer not working, put a new bulb in still not working
    Unplug it.
    There is usually a switch that gets frozen in the closed (door) position.
    Try looking in the freezer, front and center, ceiling area.
    If the switch moves easily, then it could be the socket.
    If it is iced up, wipe it with a warm wet cloth in the same direction that the door opens and closes to get it to spring back.
    Plug it back in.
    If that doesn't help post a model # and I'll continue the walk through.
    Feb 23, 2015 | Amana ARB2217CSR Bottom Freezer...
    How do I replace my freezer light
    An owners manual I found online says:
    Freezer
    1. Pinch rear tabs on light cover and pull straight down.
    2. Remove light bulb.
    3. Replace bulb with appliance bulb no greater than 40 watts.
    4. Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
    The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
    Aug 05, 2014 | Amana ARB1917CSR Bottom Freezer...
    My amana refrigerator is not cooling, freezer is working
    Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
    Click this link below and follow the troubleshooting:----
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    This will help.Thanks.Helpmech/.
    Oct 22, 2011 | Amana ARB2217CSR Bottom Freezer...
    Top doesn't get cold. Freezer is cold, no air comng up into top.
    Has the unit been moved recently? If so, seek out to locate a blockage of the refrigerant line (i.e. it might have been pinched off). Alternatively it could be the fan blower (if so equipped).
    Jan 05, 2011 | Amana ARB2217CSR Bottom Freezer...
    How do I reverse the door handle on my refrigerator? Model # ARB2217CSR - Stainless steel bottom refrigerator
    Hi, the easiest thing to do is follow the instructions on page 5 of the manual, here is a link if you don't have it
    http://shop.amana.com/assets/pdfs/literature/12642722.PDF
    Hope that helps
    Aug 10, 2010 | Amana ARB2217CSR Bottom Freezer...
    My refrigerator is on the lowest setting and everything is freezing up...water, vegetables, tomatoes froze solid etc....what should i do
    i would have a close look at the thermostat i think its stuck on it may be cheapest to just put a new thermostat in
    Aug 04, 2010 | Amana ARB2217CSR Bottom Freezer...
    How to take the front grill off?
    the grill should just snap off with a pull, evenly from both sides. If coils can be accessed from the front, there are no more coils in the back. The screwed on cardboard in the back is covering a fan so it can pull air directly over the compressor and evaporate the water in the drain pan. You should periodically check to see if water is draining into the pan, if not, the evaporator may be getting heavy ice build up, therefor not cooling 100%
    Jul 15, 2010 | Amana 25" Cu Ft French Doors Bottom...
    Amana ARB2217CSR freezer not working right
    You have defrost control parts failure.
    Either defrost timer, defrost thermostat or defrost heater.
    Feb 21, 2009 | Amana ARB2217CSR Bottom Freezer...
    Jul 15, 2007 | Amana ABB1927DE Bottom Freezer...
    Refrigerators Logo
    64 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Thomas F. Schneider
    Marvin
    Marvin
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
