SOURCE: -AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
SOURCE: I have an old Honeywell thermostat (Chronotherm
you are not geting AC power from the furnace
SOURCE: my honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
SOURCE: A/C won't come on, replaced
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
