SOURCE: craftman 20 1/2 with 42 inch cut deck is leaning
If you look at the front of the mower there are two rods that attach to the front of the tractor frame. On these rods there are 3/4 nuts that are the mower rake adjustment.First start by positioning one of the blades to a front/rear orientation. <easure the height of the blade from floor at the front part of blade and then the rear.The front measurement should be a maximum of 1/4 inch lower than the rear. Loosen up the lock-nuts on the adjusting rods and turn the nuts clockwise,this will pull the front of the mower deck up.
SOURCE: toro 1991 42 inch mower doesnt cut even how do i
The blades should be a simple bolt on, how ever there are no adjustments at the blade. Your adjustments are on the swing brackets that raise and lower the deck.
SOURCE: what size belt fits swisher 44 inch cut mod. no.t
Our manual says 74" part no. 4220. We just replaced one but can't figure out how to adjust the tension.
SOURCE: Which Pulley do you adjust
Observe entire motion drive belt and position of all
belt guides and keepers.
• Remove belt from stationary idler (A) and clutching
idler (B).
• Remove belt from centerspan idler (C).
• Pull belt slack toward rear of trac tor. Carefully remove
belt up wards from trans mis sion input pulley and over
cooling fan blades (D).
• Remove belt downward from engine pulley (E).
• Slide belt toward rear of tractor, off the steering plate
(F) and remove from tractor.
BELT INSTALLATION -
• Install new belt from tractor rear to front, over the steering
plate (F) and above clutch brake pedal shaft (G).
• Pull belt toward front of tractor and roll belt onto engine
pulley (E).
• Pull belt toward rear of tractor. Carefully work belt down
around transmission cooling fan and onto the input
pulley (D). Be sure belt is inside the belt keeper.
• Install belt on centerspan idler (C).
• Install belt through stationary idler (A) and clutch ing
idler (B).
• Make sure belt is in all pulley grooves and in side all
The pulley (C) has a spring to keep tension on the belt. The only adjustment is on the spring.
Try this manual -- Click here --- Hope this helps Fix Ya up.
SOURCE: adjust steering on riding mower 42 inch
If this is your front end, I'd say you probably bent the linkage rods. 61 & 62.
Most alignments start with the steering wheel centered, bring the closest wheel in to alignment, then work the other one in. Again, on these the links often get bent.
