SOURCE: Kubota B3300SU. Tractor was running,
Let's try the obvious first, the safeties. I now I sometimes forget to turn off the PTO or forget to put the clutch down and my tractor won't start.
You may have hit a lever with your body climbing off the tractor and this is causing the problem. Check all the levers to see if they are in the correct position for starting.
Turn off the PTO (attachment drive) sit on the seat, put the tractor in Neutral, push down on the clutch. Please read the manual section on starting the tractor.
Wiggle the transmission lever (or foot control) when you have the key in the start position. Sometimes the "neutral" position is a little bit off.
Let me now if this fixed it and if it doesn't we can continue this conversation.
