SOURCE: fuel mix and manual for Echo SRM 4000
Go to www.echo-usa.com/pdf/documentation/SRM40005000edi_110107.pdf
SOURCE: Lost eyelets Echo SRM-220ES strimmer
Hi these machines are made by allpower most parts you can obtain from your local echo dealer.
SOURCE: I have an echo weedeater srm 261t it will start and idle but dies when I give it gas.
nichodemus, you can thank the epa for this. All of the 2-stroke handhelds now come from the factory set up very lean. Almost every new 2-stroke that I have bought in the past few years has needed a carb adjustment, both on the low speed needle and the high speed needle. There are tamper resistant plugs over the adjustment screws on most carbs now. Unless you know what you are doing, the dealer will have to do this.
SOURCE: echo weedeater srm 230 oi l for houseing what
See section 24 of your manual here. It has the information you want for lubing the flexible drive shaft and the gear-drive housing (if your unit is so equipped). This is a manual for the SRM230S model.
http://dl.owneriq.net/0/026b46f7-c706-4d99-8444-50bb35343992.pdf
SOURCE: on my echo srm-2100 what length should the 3 lines be?
Parts diagram shows the fuel lines: http://www.echo-usa.com/getattachment/15a14e0b-a692-4951-ab63-01add6b428f4/SRM2100_2110e_061413_2.pdf
