Master Heaters MASTER HONDA POWERED GENERATOR Circuit breakers-2500 rated watts 120 VAC/20 Logo
Posted on Sep 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
Have a 2 year old pressure washer with only about 50 hours on it. Have changed oil 3 times and never left gas in it for storage. Also use Stabil in the gas. Was running fine until last weekend after about 45 minutes of use with a fresh tank of gas. Suddenly started surging and then shut down. Restarts immediately and idles fine. After about 5 minutes process repeats. Took carburetor apart and cleaned. Cleaned spark plug, which looked in excellent shape. Ran for about 45 minutes again and then started the shutdown problem again, acting like it's out of gas. When it starts surging and catch it soon enough, if I force the governor-feed to run a high RPM, it sometimes will continue to run, but eventually will shut down. Planning to change the plug, but the problem seems more like a fuel problem, rather than ignition. Any ideas?
Anonymous
Level 2:
  • Expert 313 Answers
  • Posted on Sep 08, 2009
Anonymous
Expert
Level 2:
Answers
313
Questions
0
Helped
108879
Points
841
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
3answers
Honda GX160 firepump runs good than dies starts first pull after and repeats
Check that the fuel tank is venting properly, sounds as though the tank is not venting therefore creating a vacuum that the carburetor cannot over come. Try running the engine with the fuel cap loose to see if that alows the engine to continue to run.
Honda GX160 starts runs dies
How about the carb was it cleaned ???? It's definitely a fuel issue
23helpful
2answers
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
3helpful
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
1helpful
2answers
I have a honda gx 160 5.5 pressure washer. It's hard to start
do a full service on it , new spark plug /air filter foam , full oil change , also chane the oil in the pump end , carefully remove the carb bowl and remove any dirt/rust/water etc
ive seen gx160 engines last 10 years no problem and those were hire machines
hope this helps if it does please vote
1helpful
2answers
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
2answers
Gx160 Pressure Washer runs fine for 20 seconds Then shuts off
It could be several things...oil level, make sure its sitting on level ground...if not did you use StaBil when you laid her up for the season? If not, go to Advance Auto and buy "SeaFoam" and following directions run it for as long as it will run...make sure you have water running through the pump during tests!
Good Luck
4helpful
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 • Garden
2helpful
2answers
Honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Top Master Heaters Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Master Heaters Electrical Supply Expert? Answer questions, earn points and help others
