SOURCE: material of Sanyo titanium bowl in rice cooker
They are generally made of aluminum to reduce wieght. But sometimes they can be made of stainless steel as well.
One way to determine this is to open the inner pot and see the outside. If it is shiny (like chrome-look), then it is most likely made of steel. If it has a dull finish, or has the titanium coating on the outside as well, then it is most likely aluminum. However, the best way to determine is to directly contact Sanyo Customer Support.
Hope that helps!
Oh yes, and please rate this as fixya if you found my information useful, so we can close the problem ticket.
Thanks in advance,
IrishDruid
SOURCE: farberware 10 cup rice cooker blows fuse after replacement
yeah it has a short in it or just a wire lose from the heater.
open up and check. If you have an ohm meter check the heater. It should not be infinit
SOURCE: Panasonic SR-MM10NW Neuro Fuzzy 5-Cup Rice Cooker
After extensive web search, this seems to be the only Website listing Panasonic parts:
http://www.partstore.com
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
SOURCE: whats the ratio. how my rice to how much water..
Typically with rice it is two to one. For every cup of rice you'll need two cups of water.
I hope thie may have helped,
Tom
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
heatman101
