Boating Logo
P
Pati canon Posted on Jul 21, 2019
Why is minn Kota I pilot power cutting off- batteries are charged
Wally
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Oct 02, 2019
Wally
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
11623
Points
60
Do you have a remote-less unit Or a remote unit. Being a I Pilot I would think you do have a remote, if you left it in the box the unit is always looking for a signal that controls the computer connection.
Take the remote and remove from I-Pilot so that the system goes into manufacturing manual
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on May 01, 2009
SOURCE: minn kota problem
Same deal with mine, was using it with no problems until I turned up the trust alittle and it just quit, never turned back on nor did the circuit breaker pop. Talked to Minn Kota thy said the board might be fried as well. So took it to a authorized dealer. I had 2 issues (only minor with the motor) Easy fix for mine was under the button on the foot pedal is a small round magnet about half the size of a pencil in diameter or so. The tech said it got recessed down to far and if it should happen again just pull it up again. So took it back home re-installed and no luck, just heard a tiny ticking noise from the foot pedal, no prop movement. SO I checked the batteeries, all good. Even though the connectons had very minor corrosion I decided to disconnect all and clean them. Re-connected them and now I am back in business. Dont understand it, but hey it works until I actually test it out on the lake. Hope it helped
Anonymous
  • 10 Answers
  • Posted on May 08, 2009
SOURCE: Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Anonymous
  • Posted on Jun 28, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Anonymous
  • Posted on Jul 13, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Johnny G14
  • 8 Answers
  • Posted on Sep 07, 2009
SOURCE: how do i extend my battery cable on my minn kota
You can purchase a battery extender cable. Depending on how far you need to go, you can buy them in various lengths. I've done the same and bought a 15' extension (always buy a few more feet than you think you need). Many places carry this. I bought mine at BassProShops for $25.00 and it comes with fuses which help to make sure you never fry your motor or battery!
I left my minn Kota I pilot turn on will this be harmfull
Hi. I believe you are referring to a Minn Kota with i-Pilot GPS? If you forget to turn the power button off and the motor was not running (meaning the prop was not turning), your motor should be fine. Ultimately, if left on for long enough, it will drain the batteries and eventually turn off. This is not harmful for the motor.
For safety reasons (yourself and others), it's always best to disconnect the motor from the power source when not in use.
1helpful
WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
Can get replacement parts for my Minn Kota trolling motor FAQs
Minn kota
I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
8helpful
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
