Flashing auto all the time, cannot get oven to work at allFlashing auto all the time, cannot get oven to work at all
AnonymousMar 12, 2014
The displays shows and around and a straight line and the oven does not startThe displays shows and around and a straight line and the oven does not start
AnonymousMar 19, 2014
HBN 4302.2 SHBN 4302.2 S
AnonymousMar 25, 2014
when the main oven is on top oven/grill gets very hotwhen the main oven is on top oven/grill gets very hot
AnonymousMar 27, 2014
green oven light orange and grill coming ongreen oven light orange and grill coming on
You can't post conmments that contain an email address.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
When you changed the bulb did you turn the power off at the mains if so then you need to reset the clock on the front panel the fan will not work but all other functions will look in book it will tell you clock reset.Hope I helped.
Good Luck.
ck wiring ( tec sheet inside the panel - there on most bosch a one time thermo / or it may be a resetable one .but you will have to reset it by pushing the red button . this may correct problem . if it does it again look for a over heating porblem like the ( fan foing too slow. ) or temps prob problems. .. mm / hope this helps / feed back pls /
hi there sounds like fan oven element at back, don't worry about smoke from grill is more than likley just grease burnning off element, just leave on for a min or two
you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
HBN 4302.2 S
