My philips 27" tv has the caption continually on. I want to turn it off. Is there a way to turn it off with the four buttons on the tv? Closed caption won't turn off Toshiba Regza LTD TV
Same problem on my new 40" tried everything took it back today exchanged it. Same thing when I turned it off then on. It's there. Can't hilite the section grayed out. FONE GETTING REFUND TOMORROW . THEY USE LAst year's LG parts so probably outdated software it's a non smart tv
Cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
I have a 40" Regza and have the same problem. The CC button is set to off. I am running cable thru a DVR digital cable box and the cable provider insists that the box does not control CC - yet if I hook the cable up directly to the TV, bypassing the box, the CC goes away.
sanyo.....how to turn off jumbled closed caption
RCA LCD closed caption won't turn off.
cc wont turn off even though it is sety to off in menu
turn on closed caption on older sharp tv
nothing to do with tv because it is already off and already turned off cable box for over 2 hours to reset and still nothing
