Health & Beauty Logo
C
Cheryl Alguire Posted on Jul 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Go go elite traveler has a continuous beeeeeeep.
Rob Hill
Level 3:
  • Elite Master 1,480 Answers
  • Posted on Jul 20, 2019
Rob Hill
Elite Master
Level 3:
Answers
1480
Questions
0
Helped
518151
Points
3838
Hi, so when you first turn it on, bleep bleep ? if so check the four connections on the rear axle and frame partvwhere it comes apart
mostlb likely a bad connection there with one of pins or sockets.
regards
gewizrepairs.co.uk
1helpful
Where can I find a brake solenoid to order for a scooter traveler Go-Go electric mobility cart
Go-Go Elite Traveller (SC40E/SC44E) Parts - All Mobility Brands
https://www.monsterscooterparts.com > gotrmo > goeltrs
Items 1 - 155 of 155 - Order the Go-Go Elite Traveller (SC40E/SC44E) Parts from Monster Scooter Parts, and know you are getting quality scooter parts at a great ...
INFINFB2039 Go-Go Elite Traveller Series Troubleshooting
https://www.pridemobility.com > pdf > infinfb203...
PDF www.pridemobility.com ... NOTE: These instructions apply to the Elite Traveller, Elite Traveller Plus, and Elite Traveller Plus HD. Travel Scooters. ... What if the range per charge of my Travel Scooter diminishes over time? Determine if ... Check the charger fuse and ensure the electrical outlet is good. ... Solenoid brake trip.
Mobility Scooter Brakes for sale ' eBay
https://www.ebay.com > ... > Mobility Scooter Brakes
Results 1 - 37 of 49 - Get the best deals on Mobility Scooter Brakes when you shop the largest online ... 24VDC Warner Electric Motor Brake for Mobility Scooter & Power Wheelchair Parts ... DWR9983H019 Pride GoGo Brake Harness ... 24VDC 6.0nm Warner electric motor brake for Mobility scooters & power wheelchair.
WHERE IS THE RESET BUTTON ON MY ELITE TRAVELLER SCOOTER
https://medium.com/@rpenn123/gogo-elite-travel-scooter-troubleshooting-21ed25ab9988
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Top Elite Health & Beauty Experts
Rob Hill
Rob Hill
jws1013
Paul Carew
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
