SOURCE: Hello - I have marble tile in my bathroom..we
Try a buffing wheel on a side grinder to buff it out. Did they tell you to seal the tile or the grout most tiles are presealed and only the grout needs to be sealed periodically taking care not to get on tile cause it does dull it and takes alot of elbow greese to buff out but the above suggestion should make it a little easier.
SOURCE: what adhesives can be used over vinyl tile?
Most glue will stick to vynil tile however it is recommended to flash the floor with a b Portland cement leveler and make sure loose tiles are glued or filled
Laminated floors can be used in any room you would like
although there are some laminated floors that are more sensitive to moisture.
If you want to use laminated floor in your bathroom you will need to prevent
water from core material of the floor.
