Washing Machines Logo
G
Geraldine Hilbert Posted on Jul 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch logixx 8front loader door will not close properly. Keeps beeping and wash cycle is stuck on 103 minutes.
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Sep 27, 2019
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206126
Points
1556
To determine that the door lock is broken,unplug machine take the top off and push the drum towards the rear get your hand and locate the door lock and release the door,replace lock eric992
2 Related Answers
richroth
Richard Roth
  • 9472 Answers
  • Posted on Oct 22, 2012
SOURCE: Logixx 8 beeps at the end of the wash cycle
Start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now.
Anonymous
  • 414 Answers
  • Posted on Mar 15, 2013
SOURCE: Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Bosch Avantixx6 VarioPerfect problems
If your Bosch Avantixx6 VarioPerfect washing machine is beeping and the light is cycling through the spin cycles without any other noise or action, it could indicate a potential issue with the machine. Here are a few troubleshooting steps you can try:
  1. Check for error codes: Some Bosch washing machines display error codes on the control panel when a problem occurs. Look for any error codes or error messages that may be displayed. Refer to your washing machine's manual or the manufacturer's website to understand what the specific error code means and how to address it.
  2. Check the door/lid: Ensure that the door or lid of the washing machine is securely closed. If the door is not closed properly, the machine may not start or may display an error. Open the door and close it firmly, making sure it latches properly.
  3. Check water supply: Ensure that the water supply to the washing machine is turned on and there is an adequate water supply. If the machine doesn't detect sufficient water, it may not start or may display an error. Check the water inlet hoses and the water supply valves to ensure they are properly connected and not blocked or kinked.
  4. Power cycle the machine: Turn off the washing machine and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This power cycle may help reset any temporary glitches or errors in the machine.
  5. Contact customer support: If the issue persists and you are unable to identify the cause or resolve it on your own, it's recommended to contact Bosch customer support or a qualified appliance repair technician.
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Bosch error E23 flashing
disconnect the power the door unlock within 30 secound
Bosch exxcel washing machine
try checking/replacing the inlet water valve. hope this helps
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
2answers
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Bosch logixx 8 front loader won't start - it keeps beeping.
Yes.
Child lock active.
Hold start button 10 seconds.
Then it will deactivate.
If this is not the case, door lock fault or main board fault.
2answers
Bosch logixx 1600 exoress from leaking underneath approx middle
This video will show you how to change a door seal on this Bosch front loader washing machine
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
