WHEN I START NORMAL PROGRAM, WATER DOESN'T FILL IN, YET THE PROGRAM CONTINUES, THE DRUM SPINS EVEN NO WATER AT ALL
FIRST remove your water supply and check that the water flows correctly...
THEN...
Check you WATER SOLENOID...
Use your SCHEMATIC drawing to determine if the operating voltage is PRESENT
Answers:
YES = replace solenoid
NO = replace SCR on control board
(I think)
Are we having fun yet?
Carnac the Magnificent
SOURCE: Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
SOURCE: Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
SOURCE: WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
SOURCE: Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
