Here's a guide;
What do the battery lights mean on my mouse?
Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model
Status
Single long green blink
Rechargeable
Batteries are good. This occurs when batteries are first installed or every time that the device is turned on.
Slow green blink
Rechargeable
Device is docked in the charging station and is charging properly.
Steady green
Rechargeable
Device is docked in the charging station and does not need additional charging.
Steady green
Presenter Mouse (Japanese version)
Laser pointer is on.
Red/green blink
Wireless
Device is discoverable (trying to connect to the transceiver).
Slow red blink
Non-rechargeable
Batteries are low and need to be replaced.
Slow red blink
Rechargeable
Batteries are low and need recharging.
Fast red blink
Rechargeable
Device is docked in the charging station, but there is a charging error. Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad. Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them.
Steady red
Presenter Mouse (Standard version)
On page 2 of the manual it says:
Battery charging light. Blinking : Charging
Lit: finished charging.
So everything is still fine. At least as soon as the light burns normal.
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
If the charge lamp blinks slowly (green)
-battery is charging. If the light is off
- battery is not charging.
- Also whe charging is complete, the charge lamp stops blinking and turns off. If the charge lamp flikers (green)
- the ambient temperature is not suited to charging. Cganhe the battery indoors with an ambient temperature of 5C to 35C (41F to 95F)
- The USB cable or charging AC adapter is not properly connected, or there is a problem with the battery. Disconnect the USB cable or unplug the Charging C adapter and correctly connect it again, or chage the battery.
Please let me know if you have any questions and if this solution was helpful.
Red light indicates that the battery is charging. The light will goes off to inform you the charging is complete. Possible that the battery was alreay damaged since you left it charging overnight. Charging time is approximately 5 hours only.
I suggest that you have to replace your battery with a new one.
Feel free to send us your suggestion or comments if this solution was helpful.
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
