Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
