I just want modest overclocking for my setup. 3.2 GHz is fine. I can't understand how to get the bios settings to take over. My CPU speed software is showing 1.6 GHz all the time.
Any help will be great. Should I abandon the ASUS OC software in Windows, too, just using BIOS?
keep pressing del as u start the pc u will see the bios as far as GPU is there u can do it from the bios for overclock related thing and for other thing u can do it using the windows
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
I suggest you select "Auto" on "CPU Speed" setting in the BIOS "Advanced" Menu or adjust 18x in "CPU Frecuency Multiple" if posible for reach optimal setting.
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions.
When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu.
If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name.
Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
If you have overclocked:
1. CPU or motherboard not up to it - run at default speed; or
2. Memory - try using other memory; or
3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or
4. You may need to up the CPU B+ a bit.
If not overclocked:
a. Set BIOS/CMOS to default settings; or
b. Disable any overclocking feature (even if not used); or
c. Lower you CAS latency.
Hope this be of some help/idea. ood luck and kind regards.
6600 CPU Quad 2.8GHz
bios 703
