While cutting grass hit something mower stop running now wont start
The flywheel key has sheared and it needs to be replaced. Replacing the flywheel key is a fairly straightforward procedure. Otherwise, it will be necessary to take the mower to have someone replace the flywheel key.
Here are some steps to follow to replace the flywheel key on your own (instructions are for a toro 20016 model mower):
You will need to replace an aluminum "key" in the flywheel. Whenever you hit something, the key is designed to shear so you don't break something major.
