Short answer is no. Your mig welder power output is CV current while stick and tig require CC current.
No they are two different process. Mig is a Constant Voltage machine. Stick is a Constant Current machine.
That depends on whether you're able to make the necessary alterations,and if the machine is large enough to handle stick welding currents.
SOURCE: Mig replace tip
Pull off the extreme outer nozzle of the MIG gun. Clean the inside of this nozzle with MIG pliers or round wire brush. Unscrew the welding tip. (If it is stuck, try using a pair of pliers lightly). Clean the entire area with a regular wire brush. Screw on the new tip finger tight, but snug. Replace the outer nozzle.
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at
216-481-8100 and ask them to email you one.
please rate my answer,
Carl
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
No. Different process. different electrical characteristics of equipment.
CC vs CV
