I have a kenmore 80 series, top loader, 3spd motor, ultra rinse, heavy duty, super capacity plus, quiet pak "The washer does not drain the water out after the wash cycle. It started a month ago not spinning the water out enough but now it simply doesn't do it at all. This is weird to me because I can put the washer on the regular wash cycle and it works. It won't release the water or spin out after the wash cycle. Any help you can give me I really appreciate. I'm stuck with a washer full of water." Please help My washer will start the Rinse cycle, but then stops. I have moved the dial around to try Rinse on the various other wash cycles and it will start the Rinse process, but again stops every time at the same point during the Rinse cycle (no matter what cycle it's on). My husband manually tried pushing down the lid switch, but still nothing happened. Consequently, the washer is full of water and won't drain. Any suggestions? My washer is a Kenmore 80 Series (Model #110.2684294).
SOURCE: washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
SOURCE: I also need the answer...
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
I would like to fix the problem myself, however, I am trying to isolate what the problem could be. Any suggestions?
i have the same problem electrolux fws833a any help
My Amana NTX4501xq washer stopped working during its cylce, not sure which, but it's still full of water. I've heard things about the lid switch, but I can't get, the side panels off the portion up top, the switch is also in the front of the washer rather than the back....anyone able to help me out on this?
washing machine just stoped in the middle of the wash cycle full of water and the motor for the spin cycle or if it has a motor for the water might be unless its gravity fed is making a noise consistent noise like it wants to but not happen en i unplugged it to see if thaty woiuld reset it and nothing itys all digitol so i was hope their is a reset button i know the old washers it was the door switch underneath the back of the lid
