Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the old string head to add replacement?
The replacement instructions seem easy enough, however, I don't understand how to remove the original string head.
Anonymous
Level 2:
  • Expert 127 Answers
  • Posted on Sep 06, 2009
Anonymous
Expert
Level 2:
Answers
127
Questions
0
Helped
54259
Points
294
Untwist the nut at the bottom of the spool head to replace the string
  • Anonymous Oct 15, 2011
    There isn't a nut at the bottom on the spool head.
Remove ryobi S430 trimmer head
it has a left hand thread which means that to unscrew it you have to turn it in a clockwise direction like putting a nut on a bolt
How do i remove the head to replace the string on a Murray M2500 trimmer?
How do i remove the hend of the weedeater it is stuck on there. I believe it is stripped
Sep 08, 2014 • Garden
3answers
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Simple head gasket
No, you don't have to remove the spark plugs. That will allow it to turn easier because it cant compress in the cylinder, but not a must. As far as the rest of the removal, yes that's how it needs to be done. If you don't want to do all that work, you can ad SeaFoam. It does have good reviews, but its not the proper way to fix. Whenever you add any kind of additive, you risk causing more damage. Save yourself the future head ache and replace the head gasket. If you are confident you can just remove what you see needs to be removed, go with it. All instructions are base on a mechanics standpoint, and lets face it the more work performed the higher the payout. Just use your eyes and good judgment, You will see exactly what needs to be removed..... Good luck.
Missing the user's manual for Homelite ut20635r trimmer sold by sears
within the bump head (once opened) you will see add arrows, this indicates which direction you add the line, usually opposite to each other, you will have line hold points (4) within the cup. once you have fulled the cup head with line (octupus needed), thread each line through feeder holes and push line into housing making sure you pull line out through the feeder at same time as pushing into head. pold the hell out of everthing or it will go haywire. Vrey difficult, but after about 300 tries at it, you will still go to the dealer to do it. If you can make any heads or tales of my solution..good luck but its how you do it. Regards Russ
1helpful
Need to replace string in RTE115C, instructions feeble Checked everywhere...ready to trash and buy some other brand.
Oddly enough, the string head appears to be identical to the one for their gas model. Some poor engineering and design here. Before you buy another model, maybe take a trip to Home Depot and in the lawn and garden section you may find several trimmer parts for different models, including a Universal String Head. Try changing out the head as the stock one is a headache for many users.
2helpful
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
1helpful
How to remove old string reel from ryobi 105r
After you line up the two triangles, push in and lift. Only the top piece will come off, then the spool is inside. I kept trying to lift the whole head and then the top popped off and I realized what I was doing wrong. It is actually quite easy once you figure out the correct way and where to pull.
Jul 10, 2009 • Garden
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
