Clymer Indmar GM V-8 Inboards 1983-2003 Logo
D
Dave Robertson Posted on Jul 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm not getting max RPM on a 350 Marine inboard, it used to be 4100 now it's only 3600 rpm, I cleaned the carb and set the floats to spec but didn't see any improvement. carb is a 1410 Edelbrock
  • Gator141a
    Gator141a Nov 20, 2019
    How about ignotion, plugs, wirrs, coils?
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
  • Posted on Nov 30, 2019
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297236
Points
3055
Dont forget to check your props.
Gator141a
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Oct 13, 2019
Gator141a
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
13300
Points
62
Have you done any on shore racing?
Pete Kop
Level 2:
Scholar:
New Friend:
  • Expert 61 Answers
  • Posted on Oct 08, 2019
Pete Kop
Expert
Level 2:
Scholar:
New Friend:
Answers
61
Questions
0
Helped
9828
Points
162
Assume you are checking the max RPM when not operating the boat? If so, might have a second tach to check the gauge is okay. Naturally, if you checked RPMs underway it would probably be a dented prop. Pete
5 Related Answers
fordexpert
  • 5692 Answers
  • Posted on Jun 11, 2009
SOURCE: I have a crusader 350xl marine engine that will
For one thing the faster you idle the worst it is for the outdrive. Without changing the throttle adjustments you can change the idle characteristics. If this is a carbureted engine you will need a vacuum gauge and a place to connect it on the engine. With the vacuum gauge connected turn the air mixture screws until the rpm rises to a peak and then starts to fall favoring lean. Balance both screws if there are more than one. You may have solved your problem already. If you want to idle higher than specs disconnect the throttle cable and set the throttle stop screw to open the carb more. Follow by adjusting the throttle cable to push the throttle closed so there is tension to return to base idle without slop.
Anonymous
  • 4 Answers
  • Posted on Mar 08, 2010
SOURCE: husky 372xp - can't adjust high setting on carb to
They use a proprietary "socket" so you can't adjust it. Using a Dremel cutoff tool grind a thin slot on the head and use a screwdriver. Also, remember that technically, the saw should be under load when setting the high setting. You'll have to go for: 1) best performance 2) turn it out 1/8 turn to give it a little more fuel.
Anonymous
  • Posted on Mar 09, 2010
SOURCE: Toyota 4AGE doesn't rev out
when short TE1 to E1 the check light goes off, i puzzled. any one can help?
DHigdon
  • 133 Answers
  • Posted on Nov 05, 2010
SOURCE: what are the torque specs on edelbrock aluminum
I would think that they are the same as a regular 350 and that is 65 foot pounds.
ormond54755
Ormond Otvos
  • 15 Answers
  • Posted on Jul 09, 2014
SOURCE: Have a 351 ford commander in boat. Put new
You've failed to plug an air leak through some little tube or hole.
How to set timing on a Hyundai accent 2009
IGNITION TIMING Specifications Application/Qualifier Transmission Set Timing Spec (Min-Max) Crankshaft Degrees Set Timing Spec (Min-Max) RPM Auto Trans Gear Check Timing Spec (Min-Max) Crankshaft Degrees Check Timing Spec (Min-Max) RPM Footnote GS Auto Transmission - - Parking 0 - 10 - (1)(2) Manual Transmission - - - 0 - 10 - (1)(2)
Footnotes Note-ID Description 1 Reference only, timing is not adjustable. 2 Check timing with a suitable timing light or scan tool. If timing is not within specified range, further diagnosis of the engine management system is necessary.
2answers
Fuel delivery on carb 350 chevy marine engine
Hi!
It seems your fuel pump fails at idle speed. I would first ensure that fuel pump is well fitted, no leaks, and good diaphragm condition.
Sputtering at 5000 rpm
AT 5000 RPM? What is the redline on the XT 600? I had a XT 500 Do not remember my year exactly, I was thinking the redline was close to 5000 RPM and if that is the case you could be possibly hitting a REV limiter or floating the valves.
Have you adjusted or checked the Valve clearance lately along with the Timing chain tensioner to be sure all are within adjustment specs?
The example you gave where it does it in 2nd gear, 3rd gear, I am sure it would do it in any gear as it sounds exactly as if teh engine is running up against a rev limiter or mechanical limits of teh valve train.
1helpful
..torque specs. rod bearings. f-350 2008 diesel 6.4
6.4L Power Stroke Diesel V-8 ... 350 hp @ 3,000 rpm. Torque. 365 lb-ft @ 3,750 rpm. 457 lb-ft @ 3,250 rpm ...
Im looking for a spark plug wirng diagram for a 1966 corette 427
1966 - 1969 with 4 Barrel Carb (L36)
(Low Compression Model)
Max Brake Horsepower - 390 @ 5200 rpm
Max Torque - 470 @ 3600 rpm
Stroke - 3.76
Bore - 4.251
Compression - 10.25
Firing Order - 18436572
1966 with 4 Barrel Carb (L72)
(High Compression Model)
Max Brake Horsepower - 425 @ 5600 rpm
Max Torque - 460 @ 4000 rpm
Stroke - 3.76
Bore - 4.251
Compression - 11.0
283, 327, 396, 409 and 427 CID Engine 1965-1966
Firing Order 1-8-4-3-6-5-7-2
350 CID Engine 1969-1974 Corvette, 427 CID Engine 1969 Corvette
Hope this helps (remember to rate this answer)
2000 650 v star. rear cylinder doesn't catch and run until front reaches 1500 or so rpm. took to dealer, and after arm and 2 legs, still doesn't run well. replaced plugs (twice). haven't...
So check the compression. The valves could be set wrong or are not sealing well. You didn't mention any smoking so the piston rings should be okay. The most likely cause of the problem is a pin hole in the carb diaphragm or a carb needing to be cleaned. Go ahead and drain the float bowl then remove it. Now clean the carb with spray carb cleaner. With a bit of luck the cleaning alone will fix the problem. Please rate my answer. Thanks.
2helpful
350 chevy with elebrook carb will not idle below 2500 can you help? just rebuilt this carb. every thing went good all settings done by the book. very clean inside all jets cleaned or replaced. re check...
Manually operate the choke mechanism and watch to make sure it fully releases. Quite often mistakes can occur when putting the pieces back together and it won't fully release off fast idle.Are you absolutely positive that you didn't forget an o- ring or ball when you put the carb back together? Is there any chance there is a gasket upside down? Could the power valve be in wrong? These types of things could create that problem, there is too much gas going through your idle circuit.What happens when you turn in the idle screws? Are you sure about the timing? I don't have specs for a 1/2 ton but all the specs in my Chilton give me 6 degrees in California and 8 degrees everywhere else. These numbers cover all models of cars for a 1978 350. Hope this helps.
How to tune up a carburator
the 2 air screws on front need to be adjusted with it running for best results but start at 1 and a half turns out on ea side then start the engine and turn the screws out till you hit maximum rpm and repeat on other side when the engin is at the max rpm there set, done while on idle .2 bbl / 4 bbl / ? they both will have a needle and seat to regulate the fuel coming in make sure there clean and functioning , make sure the float floats in gas and doesnt sink . make sure the main metering jets are operating and cleaned out good and not sticking either .some carbs have a paper filter in front you need a big wrench to undo ,change the filter or discard if theres a good 1 in the line already.
2helpful
What is the timing set at for a 1983 dodge 318/automatic? the sticker under the hood is gone.
Hello snowcat426a:Not knowing for sure thing like altitude or if Calif. emissions here are all the specs. 318 w/2bbl. carb. man. or auto trans. 12 @ 750 rpm. with California emissions auto or man. trans. 16@700 rpm high altitude with auto or man. trans 16@700 rpm. If equiped with a 4 bbl carb. the specs are as follows. 4 bbl.stand trans 12@750 .with automatic 16@750 rpm. With California emissions stand. transnission 16@750 rpm. Automatic specs for California emission are not available.Heavt duty specs. man trans, 8@750 rpm.auto is the same as the man. transmission specs. Should you need further help just ask. please leave rating as this helps with feedback. Thank You for using FixYa. Roger
Top Clymer Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Clymer Boating Expert? Answer questions, earn points and help others
