SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
SOURCE: chain fell off chain saw remington 10
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
SOURCE: need new chain for remington pole saw, model
It should, I have been on this earth to long for a definate answer. Both saws have 40 drive links, are 3/8s, and a gauge of 0.050. Please verify my findings here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Have you contacted a local saw shop? With your chain as a pattern they can make a replacement in couple of minutes. Inquire by phone about a price you may be pleasantly surprised. Give them Oregon number 91VG040G (low kickback, most likely what your saw is fitted with). If you feel adept you might try a slightly more agressive chain but the odds of kick back increase. HTH
Lou
Testimonial: "thanks, chain went on easy, worked great"
SOURCE: Remington pole chain saw model 106890-02. Chain
We are in no way connected with RemingtonPower. They are no longer in production and replacement parts are very difficult to find. Often eBay is your only source of parts. Sorry. Lou
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
