Car Audio & Video Logo
Hollis Moris Posted on Jul 14, 2019
My jvc JD 418 cd receiver will not stay on - JVC Car Audio & Video
  • Patrik Parker Jul 14, 2019
    Hi Hollis Moris, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
1 Related Answer
Anesh Vassan
  • 71 Answers
  • Posted on May 24, 2012
SOURCE: JVC car audio cd receiver model # KDR-310 will not stay powered up. Shuts down after 2 seconds. What's wrong??
hi marnie, if all the power and speaker cables are connected correctly, then you might have a faulty or shorted speaker in the vehicle.your unit is sensing a fault condition. check the impedance of eack speaker connected to the unit from the harness plug. if this does not help then your unit needs to be bench tested.
What does this code means in my ford explorer 2006 v6 dohc 4.0 L, Icode is u1900-20-ic. what do i have to do in this case
Take it to a qualified repair shop, unless you know about C.A.N - controller area network - serial data communication network between modules . U1900 -20 - ic states that one of the 8 or 10 or more modules on your vehicle has stopped talking .
U1900 CAN Communication Bus Fault-Receive Error RCM REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Occupant Classification Sensor REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error SJB REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error DVD Player REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Audio Control Module (with Navigation) REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Audio Control Module REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error SDARS REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Retractable Running Board Module REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error ABS Module REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Parking Aid Module REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error 4WD Control Module REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Instrument Cluster REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 . U1900 CAN Communication BUS Fault - Receiver Error DSM REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 .
I have a 2006f250superduty code u1900 apers
apers ???? What's this ? U1900 CAN Communication BUS Fault-Receive Error ABS Module REFER to Section 418-00 . U1900 CAN Communication BUS Fault-Receive Error Instrument Cluster REFER to Section 418-00 . U1900 CAN Communication BUS Fault-Receive Error Trailer Brake Controller REFER to Section 418-00 .
Your best bet, take it to a qualified repair shop.
Will any jvc wiring harness work on a jd-dv5000 cd player?
No, not any one, theres probly a few that will, but it might not have the same features as your model. like if your cd player has a pop out screen and in order for it to work the car cannot be in drive, there is a saftey wire that you would have to connect to something. if you got the wrong harness, that wire wouldnt be there.
JVC Sirius KD-LH300 CD Player
try puting dust air remover directly to the laser lens
CD DOESN'T STAY
What error are you receiving? Usually you will receive an error code when something like that happens. aka "NO DISK" "DISK ERROR #"
Try this: Hold down "select" while holding down the "attention" button for more than 2 seconds. This should reset your cd player.
Might fix your issue.
Here's your manual.
Consult http://resources.jvc.com/Resources/00/00/94/GET0246-001A.pdf
CD Player
I'm currently having the same problem. Take the face plate off. Use a pin to reset the stereo. It'll probably stop working again, but at least you'll be able to get your cd out and take it somewhere to have the stereo fixed or replace. (STAY AWAY FROM JVC!)
JVC KD-S70R
you have a blown fuse there are 2 fuses for this unit yellow wire and red wire one of them has no power
Novice
i/ve found that sony has the best single trays (and freq range)..i would stay away from multi cd players and any jvc (jvc freq range is horrible)...your speakers must match these componets....(bose, yamaha or customize )
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
