Thetford Norcold RV Cooler/Freezer Logo
Tim Currie Posted on Jul 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A 2004 WINNIE with a NORCOLD 120xX-IM. The display keeps going out. If i disconnect the house batteries the reconnect, the unit resets but only lights up for about 5 seconds. then goes out.
Make sure batteries have 12 plus volts or control board wont work
David Spradling
Level 3:
Top Expert:
  • Thetford Master 13,522 Answers
  • Posted on Feb 27, 2021
David Spradling
Thetford Master
Level 3:
Top Expert:
Answers
13522
Questions
0
Helped
929136
Points
28390
Blow out burner area with air clogged burner tube
5 Related Answers
Anonymous
  • Posted on Jan 21, 2009
SOURCE: Alarm goes off truck won't start.
you got to press the lock or unlock button on the remote a couple times my truck did the same thing.
Anonymous
  • Posted on Apr 28, 2009
SOURCE: 2004 totota corolla reset engine light
You need to disconnect the negitive lead to your battery for at least 5 minutes. This allows the system to reset.
Anonymous
  • 10 Answers
  • Posted on Jan 08, 2010
SOURCE: air bag light on Dodge Ram 2006. No code for
could be a seatbeat buckle wiring problem. That was the case for mine
Anonymous
  • 89 Answers
  • Posted on Oct 03, 2010
SOURCE: The engine light came on
need a diagnosis tool, reset codes from it--autozone can do this for free. sometimes the code will go away after X miles of driving. This is a OBDIII issue, again a Tech II or scan tool can erase the code.
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on Nov 15, 2010
SOURCE: norcold model n611rp works on
Sounds like the unit may not have enough DC power. See the manual.
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/GasElectricRefrigerators/322323Series/tabid/472/Default.aspx
How do I reset the ECU on a 2004 Nissan frontier?
Hello. Simply disconnect the vehicle's battery for, at least, 5 minutes. Reconnect battery, start engine and let it run 5 - 10 minutes. Good luck and keep me informed; if you want to.
I have a 85 chevy winniebago itasca A body my breakers keep tripping but i check everything and there not tripped i replaced what i hoped it was and im puzzled
Then most likely GenSet breaker trip is due to a ground fault. Isolate the fault as follows.
Open all breakers in the Winnie. Start generator without the power cable from the Winnie connected. Connect power cable from Winnie and wait a few seconds. If no trip, turn on main (disconnect) breaker in Winnie. Wait a few seconds, if no trip then proceed to turn on each circuit one at a time.
Comment here with results.
1helpful
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Put in a rack and pinion on a 2004 ram truck . Started truck and turned steering wheel and steering got tight then Horns went off and airbag light came on .
did you disconnect battery ? bet you did ! you need to reset anti-theft ,disconnect battery again but first open drivers side window all the way and keep keys in your hand (auto locks may lock doors )reconnect battery when lights and horne go off put key in drivers door and turn open lock open lock 3 times that should reset it.
Reset 2007 6.0 Lumina service kilometer display
please follow this steps and fix it. God bless you
  • 1 Open the hood of the Lumina.
  • 2 Locate the negative battery terminal on the battery. This has a black wire and is identified by a negative "-" stamped on the battery housing.
  • 3 Disconnect the negative battery terminal using a box-end wrench and isolate it so it does not come back into contact with the negative battery post.
  • 4 Leave the negative battery terminal disconnected for 10 to 15 minutes.
  • 5 Reconnect the negative battery terminal and recheck the service-engine-soon light by starting the car.
1helpful
Readout says "HOT". fan stays on. Unit is not hot. Disconnected fan to save battery days later reconnected and still same. Is there a bad sending unit or T-Stat?
On a 2004 Sportsman 400 there is a sensor on the left side of the engine head, just under the thermostat housing. If that sensor is bad or disconnected the hot lamp will come on which causes the fan to constantly run. Good luck and if you need any more assistance let me know, Daniel.
Oct 27, 2012 • Polaris ATV
2helpful
2answers
My norcold N841 will not cool on AC or Gas it has power and the gas will fire up
Most of the time if the unit has lost a/c gas and 12 volts which puts the unit into a defrost mode so there is a simple reset that can be preformed by unplugging the a/c cord from the back of the fridge and the 12 power going into the control box. leave them disconnected for about 15 mins and then reconnect them in the reverse order and check the inside frezzer at the back and fins on the rightside of the inside of the fridge to see if the unit gets cold
Uniden base display does not work after chargin for 1st time.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Question:
Answer:
1helpful
Can use the phone it is only reading searching on the display.
Question:
Answer:
Top Thetford Refrigerators Experts
john h
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
