Yes, the bladder of a Sportsstuff Speedzone 2 tube can be removed to fix a slow leak. To do this, you will need to locate the valve that inflates the bladder and remove it from the tube. Once the valve is removed, you can carefully pull the bladder out of the tube and locate the source of the leak. Depending on the size and location of the leak, you may be able to patch it with a repair kit or you may need to replace the entire bladder.
It is important to note that removing and repairing or replacing the bladder can be a difficult and time-consuming process. If you are not comfortable doing this yourself, it would be best for you to take your tube to a professional repair shop.
SOURCE: what is advantage of two tubes over one?
see friend .
we have two tubes .
1 one is for pumping the air so bag fills up.
2second contains the tube for telling pulse rate .
it is easy as we have systolic as well as dystolic pressure.
through two tubes we can have better reading.
SOURCE: The right bladder has a slow leak that I can't.
use soap and water mixture and put it in a spray bottle and spray down the whole thing and it should bubble at the leak
SOURCE: Airhead jumbo dog has leak in bladder. How do I
Discribe item more then answer may be possible look an exzamin all openins for pop off pieces may have to take several things off to get to problem
