MY CANNON CHICHESTER 10575G BLEW PLUG FUSE WHILST MAIN OVEN IN USE. COOKER MADE A 'POP' NOISE , HEARD FROM ANOTHER ROOM.REPLACED FUSE- PLUGGED IN - BUT 'POP' AGAIN. NO TIMER DISPLAY. FUSE BLOWN AGAIN.MY CANNON CHICHESTER 10575G BLEW PLUG FUSE WHILST MAIN OVEN IN USE. COOKER MADE A 'POP' NOISE , HEARD FROM ANOTHER ROOM.REPLACED FUSE- PLUGGED IN - BUT 'POP' AGAIN. NO TIMER DISPLAY. FUSE BLOWN AGAIN.
AnonymousNov 17, 2008
My Cannon Oven blew a fuse while i was cooking dinner this evening it made like a pop noise and then switched off, i turned the fuse switch back on and now the main oven doesnt have any gas? the ignition works but no gas?? HELP PLEASE!!!!!!!!!!!????????????????My Cannon Oven blew a fuse while i was cooking dinner this evening it made like a pop noise and then switched off, i turned the fuse switch back on and now the main oven doesnt have any gas? the ignition works but no gas?? HELP PLEASE!!!!!!!!!!!????????????????
how do i set the clock on my cannon chichester ovenhow do i set the clock on my cannon chichester oven
AnonymousMar 15, 2014
I have a 15 month old Blanco FD9085FX freestanding cooker The clock works and the burner ignition works but the oven will not switch on at all No lights and no fanI have a 15 month old Blanco FD9085FX freestanding cooker
AnonymousMar 30, 2014
changing audible tonechanging audible tone
Time of year when clocks are put forwardTime of year when clocks are put forward
AnonymousMar 31, 2014
Clock will not light up and fan oven will not come onClock will not light up and fan oven will not come on
You can't post conmments that contain an email address.
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
If you have had a power failure, you may find that the clock has reset. If the clock has an auto setting this will be linked to the main oven only and therefore the clock will need to set to manual for the oven to work. The alternative is that the oven element has blown and this is what tripped your power, in which case you will need to replace the element. Hopefully, the first scenario is correct and will be a lot cheaper.
All the best, pls leave feedback or reply for further assistance with make and model number.
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Fault caused by trapped and therefore cut wiring to main oven valve at bottom rear of cooker causing wiring overheat melting and open circuiting electrical supply.
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
My Smeg oven will not work either. All I get is an "A" on the display, the clock has disappeared and as a result the oven won't come on. I see from other postings here I can bypass the clock so that the oven works again - can anyone advise how I do this?
hi, does anyone know where i can find the model number on my cannon chichester?
