SOURCE: Is there any code where i can lock my washing
No code, but try this........Pull out the detergent dispenser by pushing down on the blue indented tab by the softener dispenser and take it with you
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
SOURCE: How to fix error f
Hi and weclome to FixYa, I am Kelly
An F54 code is a motor over current fault. This is caused by a severe load on the motor or a bad motor bearing.
To remove the error press Pause/Cancel twice. Before removing the error.. try and find out why the motor is hard to turn. There may be an article of clothing stuck at the top of the inner tub or between the inner and outer tub. (
If the unit has previously had an ld code (long Drain) this can also cause high motor currents if the water level switch allows the washer to spin when not completely empty. Usually an ld code is associated with something stuck in the pump / pump inlet or possibly a bad pump.
Thanks for choosing FixYa,
Kelly
SOURCE: hitachi washing machine error code
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
