Why does my faucet keep coming loose? Single hole mount on quartz, with a hose.
SOURCE: need instruction for installation pull out faucet
firs you have to remove the handle
remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
take a flashlight and determine if you need an allen head screw or phillps
remove the screw( be sure to cover your drains so nos small parts get in bottom
remove the handle
depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
whatever remove anything holding the cartridge down (some require a cartridege remover)
remove, take to store match up new and replace
by all means turn water of under sinnk good luck
TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
SOURCE: price pfister faucet handle drops and turns off.
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
SOURCE: I am also trying to remove a Moen single handle
the white plastic clip needs to be removed. squise the clip together and push it out at the same time should come out fairly easy, then just pull the black piece off.
