chasis intrusion is an option in the bios, when U start the pc, press dell to go into the bios, walk trhough the settings ( I think it will be in a section advanced or security) where U can switch off intrusion.
If you purchased this motherboard recently then i would double check your power supply - get a better power supply and try that - think you may need one with two 12 volt rails.
If that does not work then I would get it RMA'd as in return it and get a replacement.
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
There is a micro-switch which detects when you remove the lid.
This can be disabled in the BIOS menu.
Switch on and press F2 or DEL key until you get to BIOS Menu (may ask for password).
Then find security menu and disable intruder alarm enable.
