SOURCE: how do I change the tax amount for Sharp XE-A101 cash register
9 => SBTL => Tax Number (1-4**) => @/TM => R => @/TM => Q => CA/AT/NS
"R": TAX RATE (0.0000% to 99.9999%) x10000
(Enter the rate in 6 digits. Leading Zeros may be ommited)
"Q": MINIMUM TAXABLE AMOUNT (0.01 to 99.99) x100
(Smallest amount for which tax must be collected)
**Up to 4 types of tax are programmable
Hope this helps!
SOURCE: cannot read #'s on cash reg. tape
Many times its not easy to seat the inker. Also these machines have 2 rubber type wheels that will harden if the inker is not changed often enough. Also some people use thermal paper in these machines and that is not good either. if you are using thermal paper try using standard 21/4" adding machine paper. The type wheels may also be filled with glonck. you also may have bad inker. if the are crumbly they wont work
SOURCE: need instruction manual sharp xe-a101 electronic cash register
You can get the manual here.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000003777.pdf
Good luck
