My Kenmore 80 series top loading washer is not filling on any rinse cycle; just water trickling in and it never moves past the cycle. It fills and washes fine on initial start of wash, but will not get past rinse cycle. Both warm and cold settings do same thing.
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad. Use this manual to access these parts and diagnose which is bad.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out. the machine probably has a cold only final rinse so it won't work properly.
1. Turn off the water supply to both hoses. 2. Remove hoses (one at a time so you don't get them confused) 3. On the washer side - look for a removeable screen inside where you just removed the hose. 4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes. 5. Replace the inlet screens. 6. Re-fit the hose to the machine. 7. Turn on water supply valves. 8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I had the same problem with my Kenmore Model 11022956102 washer and first thought that it was the water inlet valves. So I replaced them, but found the problem continued. After about 25 seconds into the rinse cycle the water only trickled in. Checking with a voltage meter I found that I lost 120V at terminals 3 & 5 on the washer temperature controller after 25 seconds. Even though the wiring diagram doesn't show the water temperature control board, since it's full of resisters and capacitors, I figured it was the most likely problem. So I ordered a remanufactured board from Parts Simple (#3407125), received and installed it. The 17 year old washer is now working fine once again. I hope this helps someone with the same problem. /s/ Paul
