SOURCE: FUSE BLOWS WHEN BLADES ARE ENGAGED CRAFTSMAN MODEL # 917.27686
Most probably you have a wire shorting to the frame of your mower.
Trace (follow) the wires from the switch, checking for any frayed, burned, or bare wires.
Repair as needed.
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: noise, idler pully rubbing against middle blade
Unless there is some other means of placing tension on the deck belt, I would say that the idler pulley does. If the idler pulley is on a pivot arm, there is a spring that typically is attached to the pivot arm, near the pulley, that attaches to a post or some other part of the deck, that creates the tension on the belt. Check the belt for proper tension.
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
SOURCE: Honda harmony 1011 - hydrostatic
is the belt very old? if so it is stretched and needs to be replaced. All belts with a heavy fabric woven around the belt averages a 5 year life span
If it is a simple rubber/nylon corded belt one year is its life span
