SOURCE: i have a mtd 13.5 horse 38 inch cut 6 speed its
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
SOURCE: Need a diagram on how to attach mower deck on 2006
Go to...
http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down tp Owners Manuals on bottom left, the enter the model and serial numbers from under the seat and follow prompts to download manual.. Hope that helps.
SOURCE: how do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
SOURCE: I HAVE A 660 SERIES MTD YARD MACHINE 17.5HP 42
I have a yardmachine snow blower and I like to know how do you take the tire off to put a new one on?
