SOURCE: outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
SOURCE: Nissan Altima no cool air blowing or hot air blowing
Hi!
It
appears we have an Air lock scenario and you will need to perform a
system Bleed.
Park
the vehicle on level ground, when cold remove coolant filler cap,
start engine and leave to idle, turn heater on full and blower to
max. When engine reaches operating temperature watch and listen near
coolant filler, keep clear as gurgling and hopefully a boil over
should occur. Top up with very warm coolant and wait as it may do it
again.
Check
for heat inside vehicle if warm replace coolant cap but keep an eye
on temperature gauge as the ~Air lock may have moved on from heater
matrix/core so proceedure needs to be carried out again from COLD.
Please
press the Blue button to appraise my FREE Efforts, Thank You!
Paul
'W' U.K
SOURCE: Air conditioning fan makes loud noise the faster you ru it.
Concerning your broken vent -- this can be caused by a broken linkage or a malfunctioning servo motor as well. these vent have air ducts the sway back and forth to adjust the dual air flow function. if the servo o linkages are malfunctioning or not connected for some reason, it will not allow total control of the air flow and temperature range. Now, if you have a combination of a flow error and temperature error as well, thai can be caused by a combination of the two.
In this case, you will need to inspect the linkages as well as the servo motor function as well. in addition, i would test the air temp sensors for there operational value. they control the temp when you adjust the coll or hot function.
Concerning the Loud noise coming from the blower fan---
This issue can be caused by a misalignment within the blower housing or, it can also be caused by some minor damage within the motor itself, causing it to rotate in a erratic manner, in return, forcing it to rub against the housing itself. the best solution here is to extract this blower fan housing and inspect for lose fan propeller and motor stability. replace parts accordingly.
PLease rate and have a great day:)
SOURCE: central air conditioner doesn't cool
The capacitor is located inside the control panel on the outside unit. It is round or oval and silver in color.It runs the outdoor fan and the compressor both.
The terminals are marked= C, /F or fan/, H or herm. C-F-H.
The microfarad rating is printed on the capacitor. Make a color code wire diagram before removeing wires.
Disconnect power to the unit. Use a insulated screwdriver to short out the terminals on the capacitor before removing it.
Take it to a garage and have them evacuate the system and refill with refrigerant. you have air and non condensibles in the refrigerant system.
