HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keeps on telling me that the printer is offline. even with the usb plugged in.
jhun T
Level 2:
Sergeant:
Champion:
  • Expert 341 Answers
  • Posted on Aug 24, 2009
jhun T
Expert
Level 2:
Sergeant:
Champion:
Answers
341
Questions
Helped
108106
Points
954
Try to plug it into the other USB slot in your computer
Keeps telling me it is off line-how can I correct it so I can print
First check on the device and printer under control panel if the status of your printer is offline or ready. If it is offline check your usb cable if properly connected and if ready state then if you send print job set to offline try to reinstall the driver. hopefully it will help you.
2answers
Printer offline
Brother printers are cost-effective printers that give up to mark printing. In addition to printing, a user can copy and scan from the printer works into a USB and also a wireless connection.
In Brother printers, offline failure happens once in a while. This writeup tells about the reasons for this error along with their solutions. We have read 'how to fix why is Brother printer offline issue' for both Windows and Mac operating systems.
Reasons that cause this irritating Brother Printer Offline Windows 10:-
1.Paper jam error.
2.Ink toner blockage.
3.Error in the network connection between your computer and printer.
4.Wicked or outdated printer drivers.
5. If the printers ' use offline mode' is selected, it may also show the offline error.
6.Wrong printer settings.
Just follow the steps which are mention on the blog to fix the Brother Printer Offline Windows 10. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
Windows 7x64, HP8000, Offline
Disconnect the printer.
Click Start
Click Control Panel
Click Printers
How many "copies" of the same printer are installed?
Delete them all
Connect the printer, and let Windows "add printer".
Error message - printer offline
Most recent printers want software installed first, please use your CD or go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=15601#DownloadDetailAct to get the software and driver for your operating system. During the installation it usually asks you to plug in the usb for detection. Give that a try.
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone faulty.in that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
2answers
OFFLINE PROBLEM
disconnect USB, go to RUN and type in services.msc and then find print spool and right click, then choose restart .plug in usb
2helpful
4answers
Offline
Hi, i have come across this kinda issue when i was working with HP for AIO printer Technician, just a simple troubleshooting.Try this below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
k24674
Grand Canyon Tech
Grand Canyon Tech
