My dispenser tray is jammed Lg Tromm wm2277hb I can not pull it out at all it gets caught only half an inch is able to be pulled out
Probably one of the plastic covers to the bleach or softener compartments is jamming the drawer.
I took off the top of my machine... unscrew the "bumpers" at the rear/top, then SLIDE the lid backward 3-4 inches. It will lift right off. You may need to slide something along the side cracks to loosen them or remove detritus if your machine is old.The dispenser compartment has a plastic lid held on with plastic clips. Loosen the clips and lift the lid to allow the drawer to slide out. (clip it back before you replace the lid to the machine).
I simply removed the little interior "lids" that kept jamming the drawer shut. The machine works fine without them. I just need to remember that bleach goes on the left and softener on the right!
You will have to raise the top if its top loading and disconnect the hose connected to it,if its the detergent dispenser and if it's the fabric softener one with the bleach dispenser with it there will be two hose connected to it and possibly some clips holding it in not sure all machines are different.
