SOURCE: breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
SOURCE: The pulse light is blinking, but the blender will not work
This worked for me - only took about 5 minutes (the amount of time it took for me to google Black & Decker and search through their FAQ)
Q. My blender stopped in the middle of blending. What happened?
A. Your blender has a motor overheat protection system that will
automatically shut off the blender when it has been running too long
with a heavy load. If this happens, unplug the blender and wait 10-15
minutes to allow the motor to cool down. Plug in the blender and resume
blending.
SOURCE: Breville hand blender doesn't blend continuously
I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
SOURCE: Breville Blender BBL600/A. Only pulse touch button
Hello
Its speed regulator electronic circuit inside is faulty. There is a control circut ot determine the time and speed of the blender. It will contain a pre-programmed IC. This board is nor a repairable one. It should be repaced as card basis. Its one touch pulse only energezes. No other speed retulation section does not works, and the IC related to this is faulty. Normaly pre-programmed; otherwise known as {PIC} ICs are programmed by the manufacturing company, and will be difficult to get from outside electronci sparepart market. So you have to contact the Breville service center to get this device repaired. OK.
SOURCE: Ninja blender second time
Put the lid on so the arrows meet up. There is a arrow on the lid and handle put them to gather and blend!
