Most thermostats need to be set at mid scale. Set yours to between 3and5. The reason for the other numbers is for some uses a warmer temperature or a colder temperature is needed. For most freezers thermostats set to mid scale will control temperature to around 0 degrees Fahrenheit.
Hope this helps!
The heating coil is probably getting plugged up. You may have heat at idle or slow speeds, but once you get going, there is not enough coolant going through it to stay warm. Get the system flushed or replace the heating coil.
This is a very common issue, If the freezer compartment is cold and making ice the problem is simply airflow from the freezer into the refrigerated section. Typically when one senses the refrigerator is warm they max out the settings on both dials the thermostat with its 1-10 settings as well as off for the compressor. This controls the compressor and temperature. The additional setting or dial is for colder freezer or refrigerator as well , However it simply opens or closes a flapper door between the freezer and refrigerator boxes. When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section. Just set the dial that does not turn the compressor off to the middle setting. One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment. Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section. If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Turning it to the right will make it colder. It will only regulate the temp. by few degrees, so if your thinking there will be a big change there won't be.
Hello, I have a Ge Monogram 42" side by side. The temp on both side are not cold enought and I tried to change the temperature setting to colder but it's went right back. All the food started to thawed. PLease help. Thanks
