SOURCE: Need instructions for a coleman salt lake tent
Are you still in need?
I have just bought one and could send you a photo of the instructions.
SOURCE: instructions on folding popup tent
dont remember how to fold up a thomas and friends mesh pop-up tent.
SOURCE: We need instructions for a Thermos pop up tent.
Is it the tent with the plastic staves? If so, just put them together and insert the rounded end into the equivalent hole on the bottom of the tent. Sit the tent upright with the doors open. Reach into the top of the tent and push/pull the chrome lever at the top until it locks into position. Sometimes you have to wiggle it around a little to get it to lock. When it does lock, you will know it because the tent is rigid. This is a great tent. We have used one for over 40 years! When you want to disassemble it, just pull down on the chrome lever at the top of the tent and reverse the procedure.
SOURCE: i have a disney princess
Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space. Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules. Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body. Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
