My ice maker will make any ice the frig is only 5 years old. It is a Kenmore coldspot side by isde refrigerator.
Make suer the freezer temp is 5 degrees or lower. If not the ice maker will not operate. Also make sure that you have water pressure at the back of the fridge. If so, you most likely have a bad water valve. It is what your water supply connects to. You can test it like this. Disconect the water line on the fridge side of the valve. Unplug the wires from the valve. Supply 110v to the plug. If water comes out from where you disconected the line, the valv is good. If not, you will need to replace it. If you can't find the answer with this. Reply back and I'll talk you through until we find it.
Please rate this solution if helpful.
