Craftsman Lawn tractor Model# 917271842 Nothing happens when key is turned in ignition switch. Turn, turn, turn, then finally the starter turns once. Then nothing. Or it turns and starts. Frustrating. Do I have a bad kill switch? Today I removed the seat and fender, replacing the fuel tank and fuel line. Reassembled and tractor started, mowed front lawn, turned off engine to open gate to back yard. Won't start. No clicks.
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
